I'm having the "car leans right when you let off the gas" problem, and I think I found the culprit. I have a loose bolt as shown here. Only problem is, I have to remove the lower engine mount to get to it
Do I have to support the engine while I remove the lower engine mount? I was reading the team forward motion site about the lower mount, but didn't mention it in the installation. Thanks!
it'll be fine. i didn't support the engine the first time i changed mine. the second time i changed it, i took a floor jack with a 2x4 piece of wood and jacked it up under the oil pan just for some security. don't jack it up until it lifts the motor, just bring the wood right up to the pan.
GO PATS!!!
