So my car has had this stupid issue for the last 3 months or so and I can't seem to find the problem.
I will be driving along with lights on or off, and all of a sudden all my gauges turn off, my radio turns off (usually resets my clock) my dome light won't work, my brake lights don't work, and my driver side power door lock wont work.
Usually to get it working again, I pull the high beam switch back a little or turn my lights off then on, and everything comes back on. If that doesn't work to get everything to turn back on usually I can go under the hood to the huge wiring clip and play with that and everything turns back on.
Sometimes, it happens every 5 minutes or more, and sometimes won't happen for a day or two.
oh yah, the blower fan stays on, but if I have the A/C on, the pump stops running, but blower keeps going, WTF?
any wiring specialists around here? or had this problem before?
ummm... have you checked your battery cables??? easy to overlook...
yah, they were tight, I checked the grounding point on the engine too.
Were they shiny clean?
Alont
everything appears to be clean and in good order, but car still keeps doing this thing, I hope somebody knows what might be wrong.
im wondering if maybe its the BCM(Body Control Module), which in our cars is located in the cluster... either that or u need a new wiring harness,or the fuse box inside the car.
it is located in the cluster? does that mean I need a new cluster?
