changing to synthetic - Maintenance and Repair Forum
Monday, April 10, 2006 12:05 AM
hey everyone i was just wondering if when changing to a full synthetic oil do i need to do a sythetic blend the first time and then do a full synthetic somewhere i thought i read that but i cant seem to find it anymore any help would be great im gunna be changing my oil this week so let me know thanks
Re: changing to synthetic
Monday, April 10, 2006 3:00 AM
go full synthetic. You can even had normal oil to syntethic oil. It won't cause any problem.
After the first oil change with syntethic, the crap will be out.
Gilles
2.3 Ho
Monday, April 10, 2006 10:45 AM
how long should u wait the first time with synthetic not the full 15k miles right the first time? is there ever any mileage that its too late to start using synthetic
Monday, April 10, 2006 10:56 AM
start using synthetic whenever your ready.
I started mine at 3K and now every 5K after that.
-Chris
Monday, April 10, 2006 4:50 PM
i got one car with 123k and one with 180k too late to start using it? lol i thought it broke up alot of crap which probably isnt a good on all the crap that builds up in an high mileage engine
Monday, April 10, 2006 5:48 PM
it will clean EVERYTHING. it's good on old parts like lifters.
If the seals are leaking, it won't stop. You can do it at any mileage and go back and forth with dyno and synthetic oil.
Gilles
2.3 Ho
Monday, April 10, 2006 6:01 PM
Mfk-223 wrote:it will clean EVERYTHING. it's good on old parts like lifters.
this is true. My Bonneville from 60 ->120K went thru synthetic and dyno depending on how much money I had at the time.
-Chris
Monday, April 10, 2006 9:54 PM
hm good to know but i still feel really weird leaving my oil in my car for up to 15k miles at a time. What about that mobil 5000 is that some kind of blend or something i used it once. if i switch to full mobil synthetic should i change it at like 5k and then 7 etc work my way up or just dump it in and go 10-15k and be good to go?
Tuesday, April 11, 2006 4:17 AM
I still do my oil change at 5000 km (3000 miles) because the filter is still the same. It gets dirty after 3000miles so I don't want to see it at 15k.
It's not because it's synthetic that is doesn't wear. If you use your synthetic for 15k miles, you're better using dyno oil.
Gilles
2.3 Ho
Tuesday, April 11, 2006 6:05 AM
I use M1 and change at 10,000 mile intervals.
The first change was at 95,000 miles on the odo.
The first change, the oil was dirty.
The second change the oil was a dark brown.
The third change...I don't know...I'll let you know!
