WTF is up with my car??? Please help me out!!! - Maintenance and Repair Forum
Saturday, April 01, 2006 8:32 AM
Alright so lately my car has had a high idle, around 1500 rmps and its very unsteady. that has been the only thing wrong with it. But yesterday I turn on the car and it idled perfect, but the gauges in the cluster dont work and i took the car for a ride and it was lagging and sputtering real bad. It did this once before, does anyone know what can be causing my car to do this? Its a 02 z24, if anyone knows what it could possibly be please post, i appreciate it!!!
Re: WTF is up with my car??? Please help me out!!!
Saturday, April 01, 2006 8:40 AM
High idle is normally caused by a vacuum leak. See what vacuum is at idle, should be 19-21psi.
Saturday, April 01, 2006 10:55 AM
Well whatever it is, its also causing my gauges not to work.....?
Saturday, April 01, 2006 1:12 PM
Dude, pop the hood and listen for a hiss somewhere. Not too far fetched for a vacuum hose to fall off.
Saturday, April 01, 2006 6:35 PM
Doesn't seem like there is a leak of any kind............
Sunday, April 02, 2006 6:37 AM
Any trouble codes? If it's affecting your gauges I'd check for a bad ground. Somebody posted not too long about about idle/bad running problems and I think they had a bad ground. Not sure if it was the same kind of car or not though.
You can't outrun the radio.
Sunday, April 02, 2006 6:53 AM
Here is that thread, check it out and see if it helps you any.
Chedder
Sunday, April 02, 2006 8:12 AM
all i gotta say is thank you red bird! I took out the battery and checked the ground, it seemed ok....but i took it out, put it back in....and now the car runs perfect, idles perfect, and the gauges work...haha. and ive been tryin to figure this out for weeks. thanks man!!!! lets just hope it solves the problems tho cuz with my luck ill go turn the car on again and nothing will work and the idle will be 5000rpms lol. but thanks for the help man!
must. go. tell. freq. z24
Sunday, April 02, 2006 3:15 PM
No problem.
