IS MY ENGINE TOAST???? - Maintenance and Repair Forum
Friday, March 24, 2006 9:08 AM
Hey friend of mine is worried about the fact that he may of over done his engine, we took the plate off the top of the engine to get to the spark plugs and his rubber boots were kinda melted ???? IS HE SCREWED? or could he maybe be okay ?? Car wont start it turns over but it acts like its not getting gas and it makes a popping noise from the throttle body when he tries to start it for more than 3sec??? WHAT DO WE DO?? Everything else is working on the car electrically as far as we can tell
Re: IS MY ENGINE TOAST????
Friday, March 24, 2006 9:21 AM
Not necessarily, you have to determine if the problem is ignition or fuel. Spray some starter fluid in the throttle body to see if it will start. If it does, ignition is probably okay, if not check for spark. Always have a fire extinguisher handy and good luck.
Friday, March 24, 2006 9:27 AM
hey we did the starter fluid and no luck sounds the same but what do u mean about check for spark?? we are about to go get new plugs and boots
Friday, March 24, 2006 9:43 AM
uh yea get new plugs and boots.. how did they melt just all of a sudden they did or wut?
Friday, March 24, 2006 9:54 AM
If you have the LD9 it involves flipping the ignition cover, bolting it down through the hole with the ground wire, and attaching old plug wires, I thnk. The procedure is in the Hayne's manual but I'm at work. Maybe someone else will have it for you. Good luck.
Friday, March 24, 2006 12:17 PM
How do you melt spark plugs? I didn't even know that could happen!
Did you replace the plugs and boots before trying it again?
