car wont start - Maintenance and Repair Forum
car wont start
Thursday, March 23, 2006 11:40 AM
When I open my door, I hear a clicking sound, when I close it, sound goes away. When I turn the key all the way nothing happens except the service light flashes rapidly.
The lights do not work, nothing works. I checked the ground wires, the battery seems fine, except I can't remove the positive terminal since the bolt is warped.
Anybody help me? 02 cavy non-eco 5spd
Re: car wont start
Thursday, March 23, 2006 1:25 PM
its a 5 speed.. try to push start it.. if it starts its the battery.
Re: car wont start
Thursday, March 23, 2006 2:41 PM
How do I "push start" it?
Re: car wont start
Thursday, March 23, 2006 3:08 PM
Well push starting it didnt do anything.
Re: car wont start
Thursday, March 23, 2006 4:10 PM
I'd guess the battery or that positive terminal that is messed up.
You can't outrun the radio.
Re: car wont start
Friday, March 24, 2006 9:36 AM
Did you check the battery cells & battery voltage?
Re: car wont start
Friday, March 24, 2006 11:11 AM
it could be the starter if the engine isnt trying to kick over. i just had mine done and thats exactly what happened, flashing check engine light and such... new starter made it all better
Re: car wont start
Friday, March 24, 2006 2:27 PM
I am not getting any lights working or anything. My friend has had a broken starter before and he still got lights working and door chimes etc...
I don't have a lot of money, or any, to spend $200 on a starter. If I do get a hold of $200 i want to spend that money to fix the problem. Not buy a starter and oops still doesnt work, now I got no money to fix the car.
Re: car wont start
Friday, March 24, 2006 3:35 PM
talk about weird it just started
i @!#$ around with everything in the car and it just started, mind you nothing worked but it somehow started, i left the key in for 10 mins.
Re: car wont start
Friday, March 24, 2006 8:31 PM
And guess what, its doing this again, this time I can get it starting within 2 mins, but wtf is going on here. It goes from having no battery power (lights dont work, nothing besides a few lights on the guage cluster work) to the whole car working good.
I know I need a new starter since its not in the best condition right now, but it sounds like a bad ground wire or something. But if it was why does nothing work, then everything, and it keep doing this? After I run it, I start it up again, starts normal.
Re: car wont start
Friday, March 24, 2006 8:47 PM
Hey i had the same problem with my battery bolt found I finally got it off by using a drill yep thats right just dont put a bit in it and close it over the head of the bolt (or whats left of it tighen and unscrew as for the rest of your problems I dunno
