2 Seperate questions, squeak and lights - Maintenance and Repair Forum
Sunday, March 12, 2006 1:26 PM
I read that when you take in your car for having the squeak up front in what sounds like the suspension most of the time they'll lube the upper strut tower mount (? no idea what it's called) Would this just be wd 40 or something similar? It was fine, and now the squeak is back. If that's all it is I'll do it myself.
Second question, my girlfriend's '02 sunfire is having something odd going on with her turn signals. When she puts them on they might flash a couple times but than they stop and stay lit. Any ideas what it might be?
Re: 2 Seperate questions, squeak and lights
Monday, March 13, 2006 7:40 AM
Your first question might be the front bushings on the front sway bar. I had mine replaced and the squeak went away.
The second might be a bad turn signal relay.
Hope this helps.
98 Z24
RIP Specks
Monday, March 13, 2006 1:56 PM
Could also be the flasher itself. I'd say swap that relay with a know good one to check first then maybe the lfasher is bad if they still do the same thing.
