ABS light on with BRAKE light on... Fuse? - Maintenance and Repair Forum
Saturday, January 14, 2006 1:37 AM
Everytime I start my car no trouble lights come on, but as soon as I put it in gear eithe the ABS light comes on or both the ABS and BRAKE (e-brake) light come on... It doesn't seem to effect the drivability of the car, I'd just like to get it fixed to save the annoyance.
Any ideas? Fuse?
My radio was stolen awhile ago and I just had the stock CD Player put back in.. Could the thief have messed up something to cause the lights?
Appreciate the help.
1998 Cavalier Z24
2002 Camaro Z28
Re: ABS light on with BRAKE light on... Fuse?
Saturday, January 14, 2006 5:40 AM
Have you checked the Brake Fluid Level.
If the level is LOW the Brake light will come ON.
If that light comes On the ABS light will illuminate to say it can't work.
Just a thought, easy things first
Alont
Saturday, January 14, 2006 11:48 PM
numerous posts about this. never seen a solution mine has been on for awhile no fuses blown and my fluid is good. who knows
Monday, January 16, 2006 6:16 AM
http://www.carquest.com/BRK_tech.htm
There seems to be loads of info here.
In the CQB 00 05 in the 2000 Carquest bulletins, there is a reference to speed sensor wiring chafing through.
This link
http://www.sundevilauto.com/auto-diagrams-abs-brakes.asp
has a nice overall picture of a system.
This link cites bad earths and wiring.
http://findarticles.com/p/articles/mi_m3102/is_3_124/ai_n13788138#continue
Really if you check:-
1. Brake fluid level
2. Both connectors and wiring on the hydraulic modulator/master cylinder
3. Wiring to all four wheel speed sensors
That's almost all you can do without having the codes read/ going to the dealer.
Was the stock CD player wired correctly?
Hope it helps, anyway
Alont
