PARTING REAPER.... possibly - General Forum
Friday, December 25, 2015 6:22 PM
I am gauging interest in parting out the reaper. You can see what the car has on it in the classifieds. Please let me know if you want anything. If i cant sell atleast half the car i wont part it out.
1. .060 bored motor (short block with head)
2. Built trans with quaife lsd diff
3. Koni races shocks
4. 2.4 dry sump oil system
5. Sparco seats
6. Scrotch harnesses
7. Bbs 2 piece wheels
8. Wilwood front brakes
9. Electric water pump
10. Turbo header
11. Fuel pumps with billet rail
12. 3 core radiator
http://www.overkillengineeringmotorsports.com/
Re: PARTING REAPER.... possibly
Saturday, December 26, 2015 7:36 AM
If you want to text me my number is 407 221 9052
Monday, January 11, 2016 8:19 AM
I am interested in the front Wilwood's with knuckles
PM me
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
Monday, January 11, 2016 8:20 AM
I'd like more info on the rear disk setup and price.
Monday, January 11, 2016 9:04 AM
Bbs 2 piece wheels
Both / prices.
Monday, January 11, 2016 10:39 AM
Koni suspension and the big chassis brace price?
Thursday, January 14, 2016 9:01 AM
Prices being updated.
Pics will follow. A few more people and I will start the part out. Right now I need to have someone lined up for the chassis and the motor and trans to make this work.
Thursday, January 14, 2016 9:04 AM
1. .060 bored motor (short block with head)-$3000
2. Built trans with quaife lsd diff-$2500
3. Koni races shocks-$1000
4. 2.4 dry sump oil system- $1350
5. Sparco seats-$750
6. Scrotch harnesses-$250
7. Bbs 2 piece wheels-$700 with BFG KDW tires- 500 miles of use
8. Wilwood front brakes- $1000 with knuckels
10. Turbo header- $450 ( called by BLWn)
11. Fuel pumps with billet rail- $400
12. 3 core radiator-$250
Thursday, January 14, 2016 9:05 AM
Chasis- Modified with rollcage- $1500
Thursday, January 14, 2016 10:04 AM
8. Wilwood front brakes- $1000 with knuckels ( Called by BLWn)
Chassis- Modified with rollcage- $1500
Thursday, January 14, 2016 11:47 AM
Engine-
Stock 96 block- bored .060-$3000
All Clevite 77 bearings
Hot tanked block
Crower I beam rods
Cp custom flat top pistons 10.1 compression
Swain tech coated pistons
Deleted balance shafts
Deleted factory oil pump system
7qt Dry sump oil system
Barnes 3 stage pump-$1350
Lightweight Factory balancer pulley
Rotating assembly fully balanced
Ported and polished head
1mm Oversized valves
Titanium Retainers
2.3 QUAD 4 HO cam shafts
2.3 QUAD 4 HO cam shaft housings
Cometic MLS head gasket .035 thick
ARP Rod bolts, main bolts and head bolts
Custom made Oil pan with heatsink
Custom made Tubular Header-$50 ( called by BLWn LD9)
Custom made LOG manifold with velocity stacks-$500
TTR upper motor mounts-$75
Poly lower Mounts and Transmission mount-$50
80MM throttle Body-$100
Phenolic head Spacer
T3/T4 turbonetics turbo
3" Dump all the way to back
Aluminum exhaust from firewall back-$200
Electric WaterPump-$300 with lines and block off plate for engine
Becool 3" core aluminum radiator-$250
160* Thermostat
Fuel LAB AFPR
Tial Waste gate-$125
Tial BOV-$125
Suspension
Custom made KONI Race Coilovers with 700# in front and 800# in back Hyperco Springs-$1000
Custom made Tubular control arms-$350
Modified rear torsion beam
BBS 2 piece wheels with BFG KDW Tires 235/45/17-$700
Front Addco sway bar with poly bushings-$80
Wilwood 4 Piston brakes front-$1000 (called by BLWN LD9)
Disc conversion for Rear brakes
N Body Knuckle upgrade in front
Camber plates front
Spherical rear Mounts in rear
Custom made Subframe brace-$75
Custom made K brace-$200
Custom made rear Triangulated rear brace
ABS Fully deleted
Bump Steer Kit Custom made
Custom made Overflow tank-$40
Transmission
35k mile 01 Getrag transmission fully torn apart and checked over-$2500
Quaife LSD
Spec stage 4 clutch
Rk sport Aluminum Flywheel
ARP Flywheel bolts
Custom fit LD9 jackshaft.
Fuel
10 gallon fuel cell
2 Walbro 255HP Out of tank fuel pumps
Fully walked AN fittings and hose front to back
42# Green tops injectors
Custom built fuel rail-$400 with lines
Aeromotive Adjustable FPR
Other
Custom built roll cage 8pt
AEM Boost controller- $100
AutoMeter boost gauge-$35
Autometer Water temp-$35
Innovate Wideband-$150
AutoMeter Oil Temp-$30
AutoMeter Oil PSI- $30
Sparco seats- $750
Scrotch 3" harnesses-$250
Emergency Battery cut off switch
Front and rear Tow Hooks- $15
Monday, January 18, 2016 7:07 AM
Part out is happening. Will start pulling it apart this week. If you are interested in something please let me know.
THESE ARE MOSTLY ONE OF PARTS THAT YOU WONT BE ABLE TO GET EVER AGAIN.
Friday, January 22, 2016 12:47 PM
DFF- Breaking The Boundary wrote:Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
Custom made Tubular Header-$450 ( called by BLWn LD9)--------------------------------------SOLD
160* Thermostat
Fuel LAB AFPR
Tial BOV-$125
Suspension
Camber plates front
ABS Fully deleted
Transmission
Quaife LSD
Spec stage 4 clutch
ARP Flywheel bolts
Fuel
10 gallon fuel cell
Other
Sparco seats- $750
Tuesday, January 26, 2016 5:55 AM
Subframe Brace, K Framce brace, and overflow tank. if they're not already claimed.
Tuesday, January 26, 2016 6:21 AM
Davis Brown wrote:Subframe Brace, K Framce brace, and overflow tank. if they're not already claimed.
Damn it Davis I came on here just for the over flow tank. Go buy parts for your evo all ready! Lol
Tuesday, January 26, 2016 7:08 AM
wait aren't you selling all your stuff to get an evo and parting out your own cavy?
2010 Lonestar Bash 2nd place J-Body Street Class
2011 texas heatwave 2nd place american compact street class
Wednesday, January 27, 2016 6:28 AM
Wednesday, January 27, 2016 6:36 AM
Hot tanked block
Crower I beam rods
Titanium Retainers
Phenolic head Spacer-$20
T3/T4 turbonetics turbo-$300
3" Dump all the way to back-$250
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Suspension
Custom made KONI Race Coilovers with 700# in front and 800# in back Hyperco Springs-$1000----SOLD
Custom made Tubular control arms-$350----SOLD
Front Addco sway bar with poly bushings-$80----SOLD
Camber plates front---SOLD
Spherical rear Mounts in rear---SOLD
Custom made Subframe brace-$75----SOLD
Custom made K brace-$200----SOLD
Custom made rear Triangulated rear brace----SOLD
ABS Fully deleted
Bump Steer Kit Custom made-$50----SOLD
Custom made Overflow tank-$40----SOLD
Transmission
Quaife LSD
Spec stage 4 clutch
ARP Flywheel bolts
Fuel
10 gallon fuel cell
Other
Autometer EGT- $50
Sparco seats- $750
TOYO TAILS- $150
projector headlights--$50
Hp tuners computer-$50
Engine harness with computer- $150
Wednesday, January 27, 2016 6:38 AM
were all the items i requested sold to me? or?
Wednesday, January 27, 2016 1:39 PM
Pm sent
Wednesday, January 27, 2016 1:55 PM
All Pm's replied to. I will be starting the disassembly this week/Weekend.
Wednesday, January 27, 2016 9:25 PM
Specs and price on rear disc brake kit if not already sold?
Thursday, January 28, 2016 6:27 AM
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Intercooler- $300----Hold for Trey Reed
Suspension
Disc conversion for Rear brakes--$300
ABS Fully deleted
Transmission
Quaife LSD
Spec stage 4 clutch-$200
Rk sport Aluminum Flywheel-$200
ARP Flywheel bolts
Fuel
10 gallon fuel cell
Other
AEM Boost controller- $180
Autometer EGT- $100
Sparco seats- $750
TOYO TAILS- $150----Hold for Ecoswapped
Intercooler piping- $150
Couplers-$30
Thursday, January 28, 2016 7:06 AM
Still wondering what rear disk swap it is, as well as the specs on the turbonetics turbo (size, ball or journal bearing...)
Thursday, January 28, 2016 8:21 AM
I PM'ed you. Its a Neon rear swap.
Turbo is a t3/t4 Turbonetics with a upgraded 60 trim journal bearing. If it was a BB unit it would be way more than 300$
