fuel issue with codes - General Forum
Saturday, January 15, 2011 12:06 PM
i was driving today and my car a 2004 sunfire 2.2 ecotec manual trans 104,000km, died on me i cant hear the fuel pump turn on but i am getting the codes P0201,P0202, P0203, and P0204, P0455, and P0452, does this mean my injectors are gone or my fuel pump from what i was reading the p0201-p0204 are the injectors and i cant see all them going at once and i should be able to hear the fuel pump when you turn the key on. the car was running great until it died
Re: fuel issue with codes
Saturday, January 15, 2011 10:37 PM
You're right - you should be able to hear the fuel pump prime for three seconds when you first turn the key from lock to ON. If you don't hear it.. check the fuse, the relay under the hood.. and the connector at the tank. If there's power to the pump but no fuel.. then you need a new fuel pump.
Sunday, January 16, 2011 4:44 AM
so why am i getting codes for the injectors if the fuel pump is bad, thanks for the help
