Mounting Brickyard Spoiler - Exterior Forum
Saturday, September 15, 2007 7:49 AM
I just purchased a used Brickyard, is there a template available for drilling the mounting holes? Or do I need to just measure and hopefully be right?
Re: Mounting Brickyard Spoiler
Saturday, September 15, 2007 11:42 AM
Stick some oil, grease or toothpaste on the pegs of the spoiler, and set it where you want it....mark where the fluid was left on the trunklid, and drill there...
Saturday, September 15, 2007 11:56 AM
sounds like a try.
It has holes, not studs in it, so I will just screw studs up into it then do your method
Saturday, September 15, 2007 1:51 PM
Check this out:
http://www.j-body.org/forums/read.php?f=7&i=305126&t=304018&p=1
CAS wrote:
hypsy(the12secondone) wrote:how do all 3 pieces attach? screws in the middle, tape on the sides?
After taking a look at my spare spoiler, each piece takes 3 bolts, 3 washers and 3 lock washers with mounting gaskets. The brake light is attached by tape. Here are pictures:
Instruction sheet:
Brake light:
Spoiler side extension (has a vent hole):
The spoiler mounting holes are approx. 18.5" apart: (Cat's name: Sophie)
Brake light mounting location and wiring access hole:
Trunk mounting/Brake light wiring access hole:
Note the mounting access holes on the trunk:
Rear quarter panel mounting location (above brake lights):
Installed:
Any questions?
NCR-SCCA
Saturday, September 15, 2007 8:01 PM
Thanks
