is there is a difference between the 97-99 and 00-02 ecu's for the 2.4?
and can i use a 00 tune on a 97 2.4?
thanks
CCasper
the ecu part #'s are different
97-99 used the same pcm and 00-02 used the same pcm
as far as i know the programing is set up different
in the 00-02 there was a seperate bcm that controls certain things where as the 97-99 pcm would control those things in it self someone else could prob add more to this
ok cool thanks guys.
i need to find a 97-99 2.4 stock tune then.... does anyone have an .hpt file??
