Yes I have it
Im a total newbie in tuning so I will ask stupid about that
Can I copy all the table from the gm reflash in my table, install a 2 bar map and start with that to tune my engine ?
Please post you stock fill so others can view it to ensure it is SD, and also do you have one or two O2 sensors?
The car have one o2 sensor
also, post up a vin if you feel comfortable doing it....if we get enough speed density and alpha n tunes, maybe we find a vin-decode to get the SD file.
Well hot damn.
It seems most SD 97's.. only have one O2 sensor.
Does it have the " IPW vs VAC table."
With out it adjusting for boost is not really going to happen.
-MD- LD9 wrote:Does it have the " IPW vs VAC table."
no this table are missing
Which makes it useless for boost.
Back to the drawing board...
At least for a full SD pcm.
-Chris-
-Sweetness-
-Turbocharged-
I dont understand why is useless in the gm tune they dont use this table
In the 00+ M45 Tune they USE this table.
-MD- LD9 wrote:Well hot damn.
not 100% correct. my 97 is a single O2 and it is alpha-n based.
1997 Cavalier Z24
Bomz Short Ram Intake
Vibrant Cat-Back
KYB GR2 Struts
Goldline 1.75" Springs
RK Sport Upper Insert
RK Sport Lower Dogbone
Custom Tune by Shane @
innovativetuning@rogers.com
15.647 @ 88.02 MPH
-MD- LD9 wrote:In the 00+ M45 Tune they USE this table.
I dont know how they use it, all the cell in this table are set to one
so would it be possible to have a SD 5spd 97 car?
i know of a 97 that has only one 02, thats why im asking...
z yaaaa wrote:so would it be possible to have a SD 5spd 97 car?
Yes, most are.
there already is a tune kicking around here of a 1997 SD 5speed. some one (wrenchmonkey?) was trying to adapt it to work for the auto, but i dont think it was fairing too well. i had originally thought mine was SD when i discovered i only had one O2 sensor, but shane confirmed i was wrong by looking into the file and finding out it is in fact alpha-n based... doesnt bother me none since im N/A and we have learned to compensate for things and tune it properly.
1997 Cavalier Z24
Vibrant Cat-Back
KYB GR2 Struts
15.647 @ 88.02 MPH
