Aftermarket Pulleys for the GM LD9 S/C Kit - Boost Forum
Friday, April 13, 2007 6:05 PM
I was wondering what the boost levels are with the stock and aftermarket pulleys.
Am I correct in assuming that stock pulley(which is I believe 2.8") - allows the S/C to generate about 4.5-5 lbs of boost.
- So what does the follow pulley sizes generate.
- 2.7" pulley (68.6 mm)
- 2.6" pulley (66.0 mm)
- 2.5" pulley (63.5 mm)
Also am I correct in assuming that the maximum recommended boost that can be run on a stock motor with out an intercooler is about 6 psi.
Re: Aftermarket Pulleys for the GM LD9 S/C Kit
Friday, April 13, 2007 6:32 PM
Y'know if you actually take a few minutes to look for this stuff yourself, you'll find it.
Try it.
14.330 @ 96.37mph
Friday, April 13, 2007 6:42 PM
this is what i saw
- 2.7" pulley (68.6 mm) = 6 psi without alky never had on with alky
- 2.6" pulley (66.0 mm) = 8 psi without alky saw 13psi with alky
- 2.5" pulley (63.5 mm) = spins too fast for my liking
Friday, April 13, 2007 7:21 PM
You know - BlownBlackZ - did you ever think that maybe I had already attempted a brief search(about 10 minutes) before starting the thread, and didn't find the information I was looking for?
Remember a person who asks questions is attempting to learn something, and therefore should not be made to look like an Idiot, for simple asking a question.
Future Note - next time someone makes - what you may consider to be a silly post. How about giving them a little credit, and maybe offer some helpful information - maybe post a link - instead of jumping on their case, for asking a question. After all everyone here to learn & share useful/helpful information to other j-body owners.
Btw - LAFNGAS, Thanks for the info. It helps, and is basically the kind of information I was looking for.
And actually brings up another question
Does alky injection really increase the boost by about 5 psi? or is it more of a percentage increase?
Friday, April 13, 2007 9:50 PM
thats just what i saw on mine but i had also swapped out my air intake for a different style as well
Friday, April 13, 2007 10:56 PM
Alky injection is more for cooling the air. The smaller the pulley the faster the sc spins the more the heatsoak. Once you heatsoak it any gain you were getting froma smaller pulley will be gone. I would highly reccomend getting alky injection before you go to a smaller pulley. Without it you not be able to use the full potential of a smaller pully. It also has far more benefits one of the biggest being it helps drastically to prevent detonation damage.
Saturday, April 14, 2007 12:48 AM
Wade Jarvis wrote:detonation damage.
and U certainly know about that now dont u!!!!! bahahahahahahaha!!!
question, scott... how does alky injection create more boost? does it just allow the S/C to become more effient and thus making it easier to make boost?
Saturday, April 14, 2007 5:09 AM
I would actualy see a slight loss in manifold pressure when the alky system was functioning properly.
With my engine I was seeing:
2.6" 4.5 PSI
2.5" 6 PSI
2.4" 7.5 PSI
Keep in mind this was not a stock top end on the motor. Obviously a stock top end would flow less and your manifold pressure would be higher.
Saturday, April 14, 2007 9:54 AM
it just allows the s/c to keep cool so the incoming air stays cold as well and reduces the heatsoaking effects that makes the blower fall on its face
Saturday, April 14, 2007 6:26 PM
From my(fairly limited) understanding of how boosting works - is this.
If you attempt to force a lot in air into a small space, you increase "boost" pressure. But if you attempt to force the same amount of air in a larger space - then the "boost" pressure is less.
Also if I recall - doesn't cooler air mean - denser air - denser air means increased pressure - i.e. more boost.
Saturday, April 14, 2007 11:09 PM
kj1168 wrote:From my(fairly limited) understanding of how boosting works - is this.
as you said about the boost pressure and forcing the amount of air in a larger space, boost is a measurement of resistance ie. port and polished head will show smaller boost pressure
Sunday, April 15, 2007 11:31 PM
So P&P not a good idea for helping to making boost.
What about Compression Ratios - I keep hearing that CR above 10:1 is bad for making boost also - or rather bad for the engine.
Monday, April 16, 2007 12:16 AM
kj1168 wrote:So P&P not a good idea for helping to making boost.
A ported head is a GREAT idea for boost. A ported head may show lower boost levels but what your looking for is more CFM entering the combustion chambers. A ported head will be more efficient and create more power with boost. Dont be so focused on boost focus more on CFM as thats what really matters.
Reason being you could create 25 psi through straw sized intake manifold and what good would that 25 psi do... nothing.
Now put 5 psi through a slutty blondes vagina and look we have power now all because it flows better.
sorry if i went a little OT on that.
Monday, April 16, 2007 2:46 PM
^^^Nice analogy
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Monday, April 16, 2007 4:14 PM
Tom........... weard do you speak from.... never mind....
FYI, on my blower with watter injection im seeing up to, what Tom, 158 KPA... or 8-9 PSI with the stock pulley, im just reving out to 7 grand....maby im floting valves... but it pulls nice.
also with the 2.5" pulley i was only seeing 6-8 PSI...... but it was warn out (my first GMSC) this one is being treated better and runs harger with HPT.
. i have my eyes set on the LSJ M-62 and makeing it work on a LD9.
Chris
'02 Z-24 Supercharged
Monday, April 16, 2007 6:43 PM
Ok - So P&P is actually good as for air flow, which helps make more power. Understand that.
Would it be better to find a 086 head and put on the LD9, or just do a mild P&P on the stock head, with the GM S/C.
Tuesday, April 17, 2007 9:29 AM
kj1168 wrote:Ok - So P&P is actually good as for air flow, which helps make more power. Understand that.
If you do no other mods id go with a ported stock head as a 086 will bump the compression up too much for boost from the m45 (it gets way too hot to have a safe tune with the compression level)
Now if you rebuild and get lower compression pistons id go with the 086 but remember the intake manifold bolt positions are different on the 086 compared to a stock ld9 head.
Tuesday, April 17, 2007 8:16 PM
Okay. So P&P the stock LD9 head is better than the 086 head for Boosting, since it won't raise the Compression ratio.
I was kind of wonder since I had heard that using 086 head on stock CR really increased the CR by 1.5-2 full points (roughly 11-11.5:1).
And I've always heard that even if running a low amount of boost (about 5-7psi) that it's good to keep the CR at or below 10.0:1.
Tuesday, June 05, 2007 11:58 AM
anyone know were i can buy the 2.6in or 66mm pulley i would realy like one
Tuesday, June 05, 2007 12:26 PM
PulleyBoys 2.4L M45 Pulleys
1997 GMC Sierra
2005 Honda TRX450R
Thursday, June 14, 2007 11:39 AM
well im running 5 psi with the stock pully i have the 2.7 and 6 comming in ill try them both and let you know my supercharger only has about 1000 miles on it now
<img src="http://img46.imageshack.us/img46/227/cave10wf.gif" />
Thursday, June 14, 2007 12:18 PM
Ah! so it IS true! Blondes do have more fun!
I shall never doubt the pron collection again!
Thursday, June 14, 2007 12:21 PM
any other place to get the pulleys other than pulley boys? I don't intend on changing them out..... ever so whats the point of getting a quick change hub
Thursday, June 14, 2007 5:05 PM
the eco's a 6 rib belt.... get one on ebay thats for a GTP.......
Chris
