picture request for intercooler piping on 2200 - Boost Forum
Thursday, February 23, 2006 6:48 PM
like title says i have all the piping and the intercooler and i want to set it all up before i put the turbo on just so its out the way . here is a pic of the intercooler..
i just ned some suggestions i am taking off the front bumper tommorow and mount the intercooler and routing some of the piping . its 2 1/2 inch piping also .
Re: picture request for intercooler piping on 2200
Thursday, February 23, 2006 7:40 PM
if you're making custom piping you're going to need the turbo mounted and the intercooler mounted before you make the piping. Theres no way you'll be able to "set it up" before hand unless you have a set of pre-fabricated charge pipes. Youre better off to mount both of them , measure and start cutting. IF you have pre-fabricated pipes....well then just ignore everything I've said.
Thursday, February 23, 2006 7:50 PM
where did you buy that intercooler?
Thursday, February 23, 2006 8:01 PM
ebay ... why?
Thursday, February 23, 2006 9:14 PM
Good luck running that tubing, man. Without drilling a hole in the pass. side wall, the only way I saw to use an intercooler like that was to run the tubing under the condenser. My car's so damn low, that wasn't an option, really. Instead, I went with a FMIC with same-side inlets and outlets. Think it'll work a LOT better, honestly.
Friday, February 24, 2006 9:04 AM
2200 charge piping ..........................
there.......
Lee
JDM Civic Hatch
Friday, February 24, 2006 9:15 AM
Agent Omega wrote:Good luck running that tubing, man. Without drilling a hole in the pass. side wall, the only way I saw to use an intercooler like that was to run the tubing under the condenser. My car's so damn low, that wasn't an option, really. Instead, I went with a FMIC with same-side inlets and outlets. Think it'll work a LOT better, honestly.
Why is that?, all you have to do is run a u-bend or a couple 90's around the radiator and condensor. At least thats what I did, along with alot of the 2200 guys.
Failure is not failure if you learn from it
Friday, February 24, 2006 10:01 AM
well here........
this proves your point ^^^^^^^^^^^^^^^^^
any other questions............ just ask
Lee
JDM Civic Hatch
Friday, February 24, 2006 1:54 PM
I also said that my car was really low and that I didn't want the tubing to be even remotely close to the ground.
Also, when all your tubing is made out of stainless steel, using that much is a downright waste of money. For me, at least.
Friday, February 24, 2006 4:46 PM
Agent Omega wrote:I also said that my car was really low and that I didn't want the tubing to be even remotely close to the ground.
you don't think my car is low ?????
either way in this picture shown here:
you will notice that the stock part of the car is actually lower then the piping is, so if your scraping that, you still won't hurt the piping, I have never once scraped the pipes.
I spent like 400 for all the piping, couplers, and my bar and plate intercooler, that is cost effective enough for me
Lee
JDM Civic Hatch
Friday, February 24, 2006 4:50 PM
Awsome pics lee. I was wondering how you did that. I am going to be tring to put my front mount on this week end.
Friday, February 24, 2006 5:32 PM
man thats alot of piping couldnt you of clocked the turbo downward to save you 2ft worth of piping
R.I.P. Brian Klocke, you will never be forgotten
Friday, February 24, 2006 7:11 PM
^^^^^ He's internally gated, so he couldn't clock the turbo do to the gate and the fan assembly, at least I think thats what he said.
Friday, February 24, 2006 7:16 PM
Everyone's got their own "bag." I like my method better--no harm, no foul. Especially since I have to hand-polish all my piping to look like my intake. The less the better.
Saturday, February 25, 2006 1:42 PM
Boosted2point4 wrote:man thats alot of piping couldnt you of clocked the turbo downward to save you 2ft worth of piping
Yes it is a lot of piping, but I have virtually no lag....... seriously......... the turbo is sized perfectly to create an efficient set up
02turbo wrote:^^^^^ He's internally gated, so he couldn't clock the turbo do to the gate and the fan assembly, at least I think thats what he said.
you are correct, the swing arm on the actual turbo is in 1 spot, you can't move the swing arm location, and the fan is definitely in the way....................
if I was externally gated, NO problem....
I also don't like the idea of having the hot turbo pipes running right beside the oil return.
Lee
JDM Civic Hatch
Saturday, February 25, 2006 2:21 PM
who says you cant clock the turbo down when your internally gated?
Sunday, February 26, 2006 10:14 AM
^^^^^^^^^^^^^^^ you and I both know that your manifold was created differently for YOUR app. mine isn't angled up, your wg is out of the way because of that reason.
Thanks anyways
Lee
JDM Civic Hatch
Sunday, February 26, 2006 10:20 AM
Lee, you DO realize to take out the piping this is all you need to do:
Unbolt downpipe.
CLOCK THE TURBINE SIDE.
Now clock the compressor side.
Mount wastegate to swing valve on TOP of turbo.
Make new downpipe cuz RSM f'd you again and did everything upside down.
Enjoy all the newfound room you have for piping.
-Chris-
-Sweetness-
-Turbocharged-
Sunday, February 26, 2006 10:23 AM
"I can't run it under there because the turbine is clocked so I have to run the gate under the turbo"
and I don't want to drop another $300.00 on a s.s. mandrel dp again, and redo the charge piping again ..... for get it .....
happy chris ........
Lee
JDM Civic Hatch
Monday, February 27, 2006 8:10 PM
Lee
What does the size of the turbo and no lag have to do with the excessive length of the charge pipes?
Monday, February 27, 2006 8:17 PM
becuase usually the length of the charge piping will produce more turbo lag. so since the turbo is sized right, he can use longer charge piping with out the negative effect of lag
Tuesday, February 28, 2006 9:29 AM
gtpsunfire wrote:What does the size of the turbo and no lag have to do with the excessive length of the charge pipes?
Well, long charge pipes equal more space for the compressed air to fill before the system is pressurized. This will result in what is called turbo lag.
Volumeking333(Ryan) wrote:becuase usually the length of the charge piping will produce more turbo lag. so since the turbo is sized right, he can use longer charge piping with out the negative effect of lag
My piping is very small, it is 2" charge piping, this also helps with the amount of space inside the pipes. it is small and this equals no lag because there is very little volume to fill.
2" charge pipes, people look down upon because they think they are TOO SMALL.
My theory is, since it is FORCED INDUCTION, the piping size being 2" will just help with the lag factor. whether it's being forced through 2" pipes or 2.5" pipes, it's still forced induction at the end of the day.
Hope that clears it up.....
oh.... and myself and ken2.2 use 2" charge pipes, he likes it and so do I.
Lee
JDM Civic Hatch
