anyone mounted 6.5" speakers in the front ? - Audio & Electronics Forum
Thursday, December 22, 2005 11:41 AM
i got some 6.5" speakers for the front.. cause the stock little weiners in my 00 suck.
anyone mounted the 6.5 what is needed to do it right?
Re: anyone mounted 6.5" speakers in the front
Thursday, December 22, 2005 1:58 PM
Thursday, December 22, 2005 2:55 PM
ME!!! infinity kappas i just made a bracket to fit from wood.
Sigga what?
Thursday, December 22, 2005 4:12 PM
I had my kicker 6.5'' midbass's up front, much better than the 4x6's
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Thursday, December 22, 2005 8:43 PM
I originally used the plastic adapters off ebay, however, the adapter caused the speaker too stick out too far, I cut the door panel as a result which was a mistake, and the plastic eventually cracked.
I used the crappy plastic ones as a template and cut new ones out of 3/4" MDF, I am much more pleased with the strength, sound, and mounting depth. Now I just gotta find new door panels
Friday, December 23, 2005 12:09 AM
3/4 MDF and mounted the tweeters in the mirror triangle pieces at the bottom of the a pilars... great sound
Friday, December 23, 2005 10:35 AM
in my 05 i have 4x6 with components, i bought mdf and made a custom bracket. worked great i would not do it unless you are amping like i did tho.
Monday, December 26, 2005 10:47 AM
Monday, December 26, 2005 12:04 PM
Here is how mine ended up, but i used wood rings on a fiberglass door panel.........
Monday, December 26, 2005 12:30 PM
dave's picture is all i needed. i took the bracket for the 4x6's and traced it onto some 3/4 inch wood. then took the 6 1/2 speaker and set it on the wood and traced out the additional area. bolted it up and fitment is good. now i just gotta do the other side. thanks
GO PATS!!!
Tuesday, December 27, 2005 8:29 AM
dave... what was it like once you put the door panel back on? i would like to know if i will need to modify the door panel or not.
Tuesday, December 27, 2005 12:10 PM
i made mine exactly like dave's. fits perfect. i've got about 1/4 inch to the grill in the door. no problems at all.
GO PATS!!!
Wednesday, December 28, 2005 8:36 AM
Just a little bit of fitting and fiberglassing is all it takes. Sounds really good.
Wednesday, December 28, 2005 4:51 PM
Kyle Rupprecht wrote:dave... what was it like once you put the door panel back on? i would like to know if i will need to modify the door panel or not.
Yup, no problems with clearance for me, though with different speakers you may run into problems. Mine are Infinity Refereces, with 3/8" MDF
Saturday, December 31, 2005 6:32 PM
very nice pic Dave im about to do this same thing with mine also
and not to thread jack but just curious if the panels on the sunfires come off the same way the cavs do?
The one, the only, ME.
Saturday, December 31, 2005 6:35 PM
sorry but nevermind i found out in the interior forum hahaha
Monday, January 02, 2006 12:38 AM
Wood. Use 3/4 mdf for 6.5. Worked great.
Monday, January 02, 2006 3:33 PM
I used 3/4 inch plywood because its plenty strong for a mid and secondly if water ever gets in the door that mdf will just fall apart.
Tuesday, January 03, 2006 2:31 PM
if anyone wants ill put together a how to with lots of pics for doing the 6 1/2's in the doors
Tuesday, January 03, 2006 2:34 PM
if it turns out good, it should be made a sticky. let me know if you need any help putting it together, i did mine pretty quickly and it turned out nice.
GO PATS!!!
Tuesday, January 03, 2006 2:39 PM
alright thanks
Tuesday, January 03, 2006 11:31 PM
R. J. wrote:I used 3/4 inch plywood because its plenty strong for a mid and secondly if water ever gets in the door that mdf will just fall apart.
id like to see what water did to your plywood in ur door.
warp, break, and @!#$ @!#$ up lol
Tuesday, January 03, 2006 11:58 PM
04eco (theN/Aautoone) wrote:if anyone wants ill put together a how to with lots of pics for doing the 6 1/2's in the doors
would like to see, i have 5 1/4 in my doors which are currently just chillin there they aint even working because of the mounting problem and would like to get them working.... also i think i lost my old mounts from the 4x6 speakers ????????? would definatly need some suggestions for that
Wednesday, January 04, 2006 8:55 AM
Wednesday, January 04, 2006 12:03 PM
You ever see plywood vs mdf with water. Trust me plywood holds up a lot better than mdf. mdf just completely falls apart. Even if the plywood becomes all unglued and everything the screws will hold plywood together because all of the wood is still there. I dont plan on getting water in that part of the door either though but just incase it ever happens.
