search please. i cant tell you how many times this has been answered
pros- hitting switches
cons-unless you build your own kit you wont be low enough
thought of another con- never enough air
hahah both those are good cons.
Thanks guys I appreciate your advice................ not!
I really didn't need the search instructions either. Found some reading on the pros and cons but not very good ones.
So yes I did search before I posted......Thanks.
Stefan
http://www.cardomain.com/ride/2898349
if you searched then you should have found because i know myself and striped have answered this many many times and its getting old about once a month repeating ourselfs. cuz thats how many times the pros and cons are asked is about once a month
pros:
fun
gets attention
adjustable ride height at a flip of a switch
can lay car on the ground
cons:
showboating in traffic can equal tickets
need to be maintanced
valves breaks, fittings break, lines get holes (nothing is perfect)
carry spare wrenchs to fix problems if need be.
almost same comfort as stock suspensions
bag breaks, line gets a hole = loss of fender, tire and possible rim
add this to cons.... carry about 5 extra foot of airline, and 2 extra female quick connect fittings to make a quick fix if in a bind.
pro:
SPARKS F'N OWN THE NIGHT!
dont get the impression though that it always breaks. i had air ride for nearly 3 years and i only replaced 1 line, 2 fittings and a valve (my fault for snapping a piece off, not actual failure) during that time. if you take care of it and empty the water trap and tank you should be fine. also cleaning the rubber seals every once and while is a good way to prevent a sticky valve.
