ABS clicking under soft braking at low speed??? - Suspension and Brake Forum
Tuesday, January 03, 2006 7:46 AM
My abs is making the clicking noise that it usualy makes when it is working. But it makes thi noise when I am under 50kph braking easy seems to do it easier when turning too. The abs still works perfect when you mash on the brakes and there is no abs light on in the dash. What could cause the abs to be activated when it's not supposed to be. Help!
98sunfire4dr
Re: ABS clicking under soft braking at low speed??
Tuesday, January 03, 2006 8:35 AM
Sensor is going bad, OR a wire connection is dirty. Brake cleaner does wonders if it's a dirty connection.
Tuesday, January 03, 2006 9:29 AM
Why would this fault only show up at low speeds though!
98sunfire4dr
Tuesday, January 03, 2006 9:56 AM
I don't know why. I had it happen to me though. It happens.
Tuesday, January 03, 2006 5:04 PM
It probably happens at all speeds, you just can't hear it at highway speed.
Tuesday, January 03, 2006 8:44 PM
No, it happens only at slower speeds. Mine would act up from 30 down to 10 mph mostly. It would always act normal at high speeds (>45) and very slow (<10).
Wednesday, January 04, 2006 6:23 AM
And what did your's end up being
98sunfire4dr
Wednesday, January 04, 2006 8:17 AM
Bad connection to one of the sensors (front left). Cleaned it out and cleaned up the contacts. Works fine now.
Wednesday, January 04, 2006 8:28 AM
good to hear thanks for the help
98sunfire4dr
Wednesday, January 04, 2006 3:32 PM
Weird. I've never seen/heard of that problem.
Wednesday, January 04, 2006 8:38 PM
My winter car is a 3rd gen N-Body (N generations are about the same as J only one gen older). Happens alot on them. The suspesion is very similar.
Monday, January 23, 2006 6:45 AM
well I cleaned the connectors on the abs sensors but now the problem starts at 50 kph not 40 like it did before what could be my problem? I there a way to find out what sensor is giving me the problem?
98sunfire4dr
Monday, January 23, 2006 9:59 AM
A dealer could tell you which is giving the false reading. How did you clean the contacts? Try rubbing alcohol.
Monday, January 23, 2006 10:57 AM
To clean the sensor do you have to remove it? I just pulled the connector out and sprayed it all off with wd40 and put dialetic greast on it.
98sunfire4dr
Monday, January 23, 2006 2:36 PM
Dielectric grease doesn't conduct electricity, so you put more "bad gunk" back in there.
Wednesday, January 25, 2006 4:33 AM
well I know some people that work at a saturn dealership o I tolck the car there at lunch and he put it on the tec 2 and there wa no codes and we tolck it for a drive and monitered the wheel ensors and they were all reading right and the same. So is it possible that it could still be a sensor. I am stumped now. If that's not bad enough my dam blower motor resistor went again the other day.
98sunfire4dr
Wednesday, January 25, 2006 10:45 AM
Yeah. That sensor can be a real b*tch to figure out. Mine did the same thing for months. It would never act up while I had my computer plugged into the car; would only do it when I couldn't check which sensor. I know in my cars (95 & 97) it will not store the error code, you have to pull it while the ABS light is on; IIRC new cars (maybe 00+) do store the code.
