Everything listed does NOT include shipping.
1st item up is 1 00 z24 cavailer gunmetal in color and is my recent car. now what you get is, a rolling chassis with 95z24 wheels, stock susp., stock brakes, racetronix fuel pump in factory tank with the wiring harness, all the wiring is still in the car, wire tucked with ecu, 2bar map, and injector driver.interior come with carpet, headliner that is wrapped in sparco material, rear 1/4 interior panels, and center conso, but does not have any of the dash, door panels, or any seats. exterior comes with trunk and spoiler, doors, comes with fenders but they are the blue ones, what it will be missing is a hood, bumpers,glass, headlights. this car has somewhere in the 50k miles, is a 2 owner car with a clear title the bad is, its missing alot of pieces, the way the seats where modified i changed the mounting location and cut the factory seat mount studs off so cant use factory seats without some work, but i will include the seat brackets that are made for it but use a sparco sliders. i scratched up the firewall pretty good pulling the turbo stuff off, there is some small rust starting in the rear 1/4 wheel wells which im still clueless as to how that happened but whatever. with how the firewall is modified you cant put a heater unit if you wanted to back in the car, so no heat or a/c.. now ill say that money talks and i can make this a complete car for the right price. but asking $1500
anything in the pictures that has
blue tape on it does
NOT come with the car.
Spec Alum. flywheel needs a new steel ring $35
DC strut bar $60
MSD coils and wires with bracket $100
MSD DIS 2 Ho 62113 $275
Nitrous wet system everything is new but the solenoids have been freshly rebuilt by nx $600
Nx nitrous, fuel and purge all rebuilt by nx
10lb. bottle with dynotune blowdown tube, and pressure gauge
16ft. nitrous line
shark nozzle
dynotune bottle heater
MSD digital window switch
NX tps switch
3" exhaust with megan muffler $300
2.4 timing chain housing $25
Amber painted corners (one the chrome turned black inside) $15
Blue painted timing chain cover $30
2.4 starter off a 00 $30
00 2.4 stock flywheel $ 30
2.4 coil covers $20 each
2.4 coil pack $15
blue tail 44mm wastegate spring $5
2.4 stock throttle body $25
2.3 mantapart 60mm throttle body new $100
eco fuel rail, injectors, and fpr $30
red sparco hood pins $15 sale pending
2.3 windage tray $15
1 3/4" 304 ss 4-1 collector 16gauge $30
golden eage vaccum block with fittings and lines $120
cavailer ingraved alum. door sills $30
2.4 alt. powder coated black with aem overdrive pulley( does not work since i put it back together) $30
vizzion ported head, with stainless valves, not sure on valve springs came with my car when i purchased it forever ago and i never ran it $200
2.3 086 head new rebuild $300
apex-i turbo timer $50
black cat customs gauge face, with 98 z24 cluster not sure if the cluster works correctly havent tested it in 7yrs and has been sitting in the sun for awhile $40
2.4 oil pan with -10 bung welded in $30
2.3 timing chain housing, cover, with new guides, cloyes double roller chain, tiiming gears and crank gear $120
2.4 alt with aem power pulley $50
cavalier upper dash pad started to fiberglass not finished $50
rk sport type j side skirts $80
stock charcoal with red doted front and rear seats with sliders, in good condition no stains or burns $100
charcoal carpet in decent shape $30
Sunfire aerogear millennium body kit with fender flares $500
Sunfire GT spoiler- silver in color $ 25
Turbo setup *notice* im not sure how this fits in the factory engine bay since my firewall has been modded. right now ill list as header, dump tube, downpipe $300
Edited 3 time(s). Last edited Friday, October 22, 2010 8:17 PM
R.I.P. Brian Klocke, you will never be forgotten
