Venom 400 Control Module in 2002 Ecotec????? - Performance Forum
Friday, May 23, 2008 2:19 PM
My buddy has a Venom 400 Control Module for a 98 z24 can i hook it up to my 02 ecotec lime green wire on the map and on the tb dark blue will this work or not..?
Re: Venom 400 Control Module in 2002 Ecotec?????
Friday, May 23, 2008 2:21 PM
It doesn't do anything to our cars. So there is no point in putting it on yours. Do a search and you will found out those things are junk.
Friday, May 23, 2008 2:25 PM
Mark Raimo wrote:My buddy has a Venom 400 Control Module for a 98 z24 can i hook it up to my 02 ecotec lime green wire on the map and on the tb dark blue will this work or not..?
You would be better off spending the time that it would take hooking this up and CLEAN your throttle body. It will do more for you than this will.
Friday, May 23, 2008 4:23 PM
he venom400 module gains ecotec's generally about 55whp... so yeah, go ahead and hook it up and enjoy!
Riddle me this... riddle me that...
Friday, May 23, 2008 8:02 PM
it clearly gives gains.. this will hook up then even though its for the z24 this is what your saying
Friday, May 23, 2008 10:03 PM
Mark Raimo wrote:it clearly gives gains.. this will hook up then even though its for the z24 this is what your saying
it doesnt give gains. read next time.
the library wrote:How do the TPS Tec and Venom 400 work?
The TPS Tec and Venom 400 are both electronic 'hacks' that plug into various sensors, and work quite similarly.
The Venom 400 claims to alter closed loop fuel and spark response by replacing or modifying the voltage signals into the Powertrain Control ModuleSee ECM. (PCM) from the manifold absolute pressure (MAP) and throttle position (TPS) sensors. Since the PCM uses input from the MAP and TPS sensors during closed loop operation to determine an appropriate fuel response, their logic behind this attempt is to trick the PCM into thinking that the throttle is open more than it actually is so that additional fuel will be added to the mixture. And since a mixture slightly richer than stoichiometric is generally best for producing peak power, the additional fuel should create some extra power (albeit far from the 25% increase that they claim.)
However, it is important to remember that MAP and TPS inputs only affect PCM decisions during partial throttle driving. Once MAP and TPS signals reach voltage levels that indicate full-throttle, the PCM begins ignoring these input signals and resorts to open loop operation - at which point, additional voltage from MAP and TPS sensors will not affect fuel response. In other words, the Venom 400 claims to function only under partial throttle conditions.
This partial throttle limitation is not something that is denied by the makers of the Venom 400. In fact, they openly admit this in their marketing material. They even used to publish dynamometer testing results at their website that showed power gains as a function of throttle position. If you looked closely, you would notice that the Venom 400 power curve matches the stock power curve at 25% and 100% throttle openings. And, of course, on both curves, the point of maximum power occurs at a 100% throttle opening. But at all partial throttle openings between these points, they indicate a substantial increase in power by using the Venom 400.
Specifically, at 40% throttle opening with the Venom 400, as much power is indicated as was produced at 60% throttle opening on the stock curve. And at 80% throttle opening with the Venom 400, as much power is indicated as at 90% throttle opening on the stock curve. At full throttle (100% throttle opening,) the venom curve matches the stock curve - which makes sense, since the Venom only claims to function during partial throttle operation. What they fail to mention is that the accelerator pedal - which is controlled by the driver with his or her right foot, determines the amount of throttle opening. So by simply pushing harder on the accelerator pedal, you can open the throttle as far as you want - for free. In other words, you do not need to spend money to go faster from a partial throttle position. You need only to open the throttle further until one of two things happens: 1) the car goes as fast as you want or 2) you reach full throttle and cannot push the pedal any further (at which point, the Venom 400 is useless since it only functions during partial throttle operation.)
So our advice is this: if you want your car to produce the power of a 60% throttle opening, just push harder on the accelerator pedal until the throttle is open 60%. And if you want your car to produce the power of a 90% throttle opening, just push harder on the accelerator pedal until the throttle is open 90%. And if you want even more power than that, push the pedal to the floor so that the throttle is open 100%.
This method does not cost anything, yet it accomplishes the same increase in power as Python Injection claims to deliver with the Venom 400
Friday, May 23, 2008 10:09 PM
proof of these gains???
Saturday, May 24, 2008 8:34 AM
Im going off of what of what z yaaa said and my buddy that had it in and all the reviews if you guys say it doesnt then i dk maybe it doesnt, but i was told it leans the car out not adds more fuel which would make a little bit of sense adding more fuel wouldent without the right amount of air to accommodate, but leaning out would make a more violent explosion, idk im just asking if it hooks up its not like im spending the 400 dollars for it, why are people saying on reviews its giving them gain at higher rpm and some say its not at all then.. i dont care about the gain right now just want to know if it hooks up the same way
Saturday, May 24, 2008 9:41 AM
Z yaaa was joking with you.
Saturday, May 24, 2008 2:16 PM
ya i figured that, but my question still is not answered will this hook up forget about gains idc if it makes 55 whp or looses me 55hp im not asking the gain i do not care i just want to know if it hooks up the same way into my car as it did the 98 z24
Saturday, May 24, 2008 4:10 PM
I never bothered with them and dont feel like looking up how it is connected to the Z. Why dont you tell us how it is hooked up to your buddies Z and maybe somebody will be able to tell you if you can waste your time hooking it up to your eco or not.
Saturday, May 24, 2008 8:49 PM
I said/ asked if its the blue on the tps and the lime green on the map sensor, is that the same wiring or is it different thats what i want to know.....
Saturday, May 24, 2008 10:58 PM
im not sure. but why would you even want this? it makes your gas mileage suffer
Sunday, May 25, 2008 5:29 AM
Is it the same color and same location in the connector in the other car? Regardless you are wasting time and risking damage to the car (depending on you skills at doing wiring) just to gain a loss in fuel economy and no gain in power.
Sunday, May 25, 2008 8:44 AM
It has the option to turn it on and off so its like being without it when its off, the way it connected on his car was theres a dark blue wire on the tps off the tb, and off the map sensor in the middle of the map theres a lime green wire.. i looked on my car its the same setup but i didn't want to wire it because theres 3 wires on the map and another sensor on the tb so it might be different wires and a differnt way to connect because of his being a 98 and mine being a different motor and an 02. So that said what do you think its the same or a differnt setup because of the motor and year change
Sunday, May 25, 2008 9:23 AM
how many wires on the TPS connector on your Eco? As far as I can recall the Eco and LD9 still have the same TPS and MAP wiring, but I could be mistaken. I dont own an Eco so I dont really pay that much attention to them when I work on one.
I still say you are wasting your time and run the risk of problems now or down the road due to messing around with the wiring on your car when you dont need to be.
Sunday, May 25, 2008 10:35 AM
I no theres 3 on the map i want to say 2 on the tps im not exactly sure on that but i know both of the wires i need to goto i saw both of them, and as far as problems i know how to wire and if i did have a problem i would know it's becuase of the venom so i would take it off, im not even positive im getting it or whats going on i just wanted to make sure the wires were the same on both cars so if i in fact did hook it up i wouldent turn my car on drive down the road and have it blow up because of 1 of the wires being differnt from the z24 to the eco
Monday, May 26, 2008 5:26 PM
It's been dyno'ed by other car owners to be useless... but why listen to us? We only speak in reason... so...
Yes the wire colours are the same. Happy gas wasting!
...j
Monday, May 26, 2008 5:52 PM
Mark Raimo wrote:ya i figured that, but my question still is not answered will this hook up forget about gains idc if it makes 55 whp or looses me 55hp im not asking the gain i do not care i just want to know if it hooks up the same way into my car as it did the 98 z24
you know, after your other post about the guy who sucked sand thru his engine to port/polish it... you may have better results if you try his method.
the 400 is JUNK. period, end of discussion. I know the answer to your question but I won't tell you because its a complete and utter waste of time and money.
go pick up a 25lbs bag of sand instead to port/polish the engine
Tuesday, May 27, 2008 8:43 AM
Yes, you can wire it the same as the Z.
It is a waste of time and money. "Period"
