LSX Spring Article-- Potentially LN2/OHV Related - Performance Forum
Saturday, April 12, 2008 12:55 AM
Well, I know we've been discussing machining down the spring seats in the 2200 head and using the longer 2.2 valves in order to facilitate use of the popular and relatively inexpensive LSX style springs.... So I started doing some digging and almost the first thing to appear on my Google search was this article from ZZPerformance. They're a mostly 3800 shop, but the article definitely has some information that can pertain to the OHV community. Bear in mind, when referring to "stock retainers" the author is obviously talking about stock 3800 retainers, so don't get confused.
Valve springs and retainers
This tech article begins with an apology to those whom this offends and those who find out that they probably need to change the setup on their engines. If I sound harsh at times, it is because of the sheer amount of false information being presented by other companies. Their lack of research and sheer desire to profit from releasing products they haven’t researched has caused thousands of dollars in un-necessary damage to many engines.
For the 3800 there are a few choices of valve springs:
Stock –tested at ~70# pounds seat pressure @ install height of 1.72
LS1 –tested at ~70# seat pressure @ install height of 1.80
LS6 blue –tested at ~90# seat pressure @ install height of 1.80
LS6 yellow –tested at ~90# seat pressure @ install height of 1.80
Comp 105 –tested at ~108# seat pressure @ install height of 1.80
Comp 130 –tested at ~135# seat pressure @ install height of 1.80
Comp dual spring-tested at ~135# seat pressure @ install height of 1.80
Comp 150 -tested at 155# seat pressure @ install height of 1.90
Tested seat pressure is only at the seat, when the valve is closed. Our values are listed for springs that are brand new. When a spring is used, it will ‘settle’ to a slightly lower pressure. The seat pressure rating of the spring does not determine how much lift the spring can handle, what the open pressure will be or how “strong” the spring is (strength meaning resistance to breaking).
Spring rate determines how much pressure the spring will have when the valve is open. This is very important because the spring pressure when the valve is opening determines the force needed to open the valve. The more force needed, the higher the stress on the timing chain system. In our case, the stock timing chain dampener. This means that the higher the spring pressure during valve opening the more wear on the stock timing dampener.
The LS6 spring increases in pressure faster than the Comp 105 or the Comp 130 (which has the same spring rate as the 105). By the time you get to .300 lift, the yellow LS6 spring has passed the Comp105 in pressure. At valve lifts of .500 (close to what a 1.9 rocker gives) the LS6 spring is up to 275#, while the Comp105 is only 250# and the Comp130 280#.
Valve float is bad. The resistance to valve float is determined by the seat pressure, not the spring rate. For the 3800 running a stock timing dampener, it makes sense to try and run the seat pressure you need to prevent valve float, coupled with the lowest spring rate to reduce dampener wear. Valve float comes from the spring’s inability to control the valve. High rpm, fast ramp rates, valve lift, valve train component weight all play a factor in how soon your setup will experience valve float.
Performance: We recommend the Comp 105 spring over the LS6 spring because the 105 has a lower spring rate than the LS6. With a lower spring rate the dampener will not wear as fast. Another little known factor is rocker deflection. This is where the rocker actually bends as its being opened because of the massive force being applied to it by the spring. A stock rocker experiences this problem the worst and loses about 25 thousandths of valve lift due to deflection. This is the same as lowering the rocker ratio by .1 (turning a 1.9 into a 1.8 and so on). This is one of the reasons why HP gains from using high ratio rocker arms have been all over the spectrum. Using a modified 1.9 ratio rocker without changing the valve springs works well because the stock springs are light and you don’t get much rocker deflection. You do risk valve float this way but most people don’t have that problem. With a roller rocker you will get valve float with a 1.9 ratio rocker unless you use higher rate springs. This however costs you a small amount of lift and is why many people running 1.9 rollers, don’t see large gains over 1.8 ratio rollers using stock springs (which works w/o valve float). That certainly gives you a lot to think about but the bottom line is this: Using the Comp105s over the LS6 springs is a good idea if you don’t mind spending the extra money.
Retainers will determine your installed height. Using stock retainers gives you an installed height of 1.72 and using and LS1 or LS6 retainer (same part #) gives you an installed height of 1.80. If you use stock retainers with any of our LS1 style aftermarket springs, it will increase the seat pressure (by ~29# on an LS6, ~23# on a Comp105 or 130, and ~18# on a stock LS1 spring) This is because you are preloading the spring .080, so when you calculate total lift on the spring you have to add .080 to it. (Using stock 3800 retainer with LS6 spring and stock retainer with a .500 lift cam, compresses the spring as if you had a cam with .580 lift! There is no instance in which you should ever run stock 3800 retainers with an LS1 style spring meant for a 1.80 install height.
Maximum lift capability of a spring is not the same thing as coil bind. A spring has a rated maximum lift that is usually around 25 thousands lower than it’s coil bind point. Any vendor that gives you coil bind specs when you ask what lift is safe, does not have the knowledge to be giving advice.
Now that you know a little more about valve springs, we’ll explore the problems in the 3800 community.
Wbody store:
They sell a “light duty” valve spring. These have a dealer cost of less than $2/spring and come stock on an LS1. Its maximum rated lift is ~.500 and it does not have any more seat pressure than a stock 3800 valve spring. If you use it with stock 3800 retainers, the maximum lift drops to .420 (1.9 rockers bring the lift to .490). This spring should not be considered for use in our market.
Anyone using stock retainers with these springs can expect the spring to fail, using LS1 retainers and you have the same valve float protection as your stock springs.
This store rates the maximum lift of the Comp 105 as .590 and the Comp130s as .630, both are actually rated from Comp at .600 and coil bind around .625
Spring rates for their light duty and medium duty (LS1 and LS6) springs are incorrect.
Intense:
When they originally offered the “85 pound” springs, they used the blue LS6 springs. They have the same cost as the yellow but do not support the same lift. This shows a lack of testing and research. On the positive side, they now sell the yellow LS6 springs.
They currently list the LS6 spring for use with a stock retainer. This changes the maximum lift from .550 to .470. This also destroys the stock timing chain dampener in 5-10k miles when using 1.9 rockers or a small cam. They have this information listed on their site and on each box of springs send out. It is very, very bad information.
Intense springs package
Failed LS6 spring with stock retainer and 1.9 rocker
Failure pic2 with stock retainer and 1.9 rocker
Picture of a stock and damaged timing chain dampener when you have too much spring pressure
At ZZPerformance, we believe in testing products and doing all the research before releasing them on the public. That is why we have taken the time to work with Comp cams, educate ourselves, inspect engines that have been run under various conditions and share the information with you.
http://www.zzperformance.com/miscftp/spring%20testing01.jpg
http://www.zzperformance.com/miscftp/spring%20testing02.jpg
http://www.zzperformance.com/miscftp/spring%20testing03.jpg
http://www.zzperformance.com/miscftp/spring%20testing04.jpg
http://www.zzperformance.com/miscftp/spring%20testing05.jpg
http://www.zzperformance.com/miscftp/spring%20testing06.jpg
So, in considering that I think it was Notec who, many moons ago, bought the last double roller timing chain setup in the known universe for the OHV, it would seem from this article that going with the Comp 105 springs may be preferable to using the factory LS6 Yellow springs... Any comments? Ideas? Feel free to discuss....
As an aside, if anyone has one of those double roller setups that they're not going to use.... I'd be more than happy to take it off your hands
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
Re: LSX Spring Article-- Potentially LN2/OHV Related
Saturday, April 12, 2008 9:14 AM
2008 GMPP Catalog wrote: 12586484
Valve Springs (not shown)
• Beehive style springs
• Standard LS6/LS3 springs
• 1.800" installed height @ 90# pressure
• 1.250" @ 295# pressure (this comes out to a rate of 373# / inch)
• Max lift .570"
12589774
• Standard L76/L92 springs
• 1.300" @ 264# pressure (a rate of 348# / inch)
• Max lift .530"
The second spring (in bold print) looks to be a better option than the LS6 Yellow stripe spring. It has the same seat pressure, but lower rate of 348 # / inch, as opposed to 373# / inch for the LS6 spring. Another plus for the L76/L98 spring is price, I've found it for $2.05 (GM Parts Direct) to $2.27 each. Compare that to the LS6 spring's price of $6.88 (GMPD) to $7.95 each or the Comp Cams Spring starting at $169.95 for 16 (10.62 each, but can only get in sets of 12 or 16 ), really makes the L79/L98 spring look really good. BTW, when pricing these, don't for get to calculate the shipping and handling costs, if your not careful you could end up paying more per spring, just for the S&H!
Both of the Comp Cams springs are rated at 313# / inch, but the seat pressure is different 105# and 130#. With both Comp springs having the same ID, OD and rate would tell you they are the same wire, but the 130# spring will have a .080" taller free hight.
For my application and the cam spec I'm looking to have reground, the open pressure will work out to be the same for both the L79/L98 spring and the Comp Cams 26915/ 105# spring.
Here's the math:
(spring rate X valve lift) + seat pressure = Open Pressure or
L79/L98: (343 X .482) + 90 = 255.326 # @ 1.318"
Comp 26915 / 105# : (313 X .482) + 105 = 255.866 # @ 1.318"
Why these springs for only .482" lift? .480" is what we've calculated to be the safe maximum lift for the stock LN2 springs, the very low seat pressure (68 #) and the rpm (although nothing super high, but fast enough to require better springs.)
Yes, I am backing down the lift I was going to use from before (.520") but from the simulations run, I only lose a couple of HP and Lbs of torque, to gain a bit more reliability and valve train stability. This new regrind will still make really good gains across the board, especially at the upper rpm ranges of my power band, compared to my current grind.
Saturday, April 12, 2008 11:17 AM
Scarab (Jersey Jay 1.8T) wrote:As an aside, if anyone has one of those double roller setups that they're not going to use.... I'd be more than happy to take it off your hands
Better idea:
Buy one of the remaining '82 gear and chain sets (there are still many out there), and try using it with the '83+ guide/tensioner...WE NEED A TEST DUMMY!!!!
MadJack wrote:With both Comp springs having the same ID, OD and rate would tell you they are the same wire, but the 130# spring will have a .080" taller free hight.
Tsk, tsk, tsk, that's not how springs work...you should know better
Saturday, April 12, 2008 12:14 PM
Care to elaborate?
Eco
Turbo
Megasquirt
Saturday, April 12, 2008 11:20 PM
Scarab (Jersey Jay 1.8T) wrote:Care to elaborate?
It has been speculated that an 83+ tensioner/guide setup would be compatible with the double-roller '82 chain and gears. Since you can still get the chain and gears...
Sunday, April 13, 2008 7:20 AM
Josh, reading this thread, got me to thinking and I looked something up. I don't know if you remember, a while back Mahle bought out AE Clevite. I did some checking and guess what I found! All the timing components for the '82 1.8L L46 motor!
Straight from the Online catalog, GM Engine Catagory 21, 112 CID (1.8L) L46 Chevrolet 4 Cyl, 3.504in./89mm (1982):
  • Tming Assembly 3 Piece # 9-3060
  • Timing Kit Multiple Piece # 9-3409
  • Tming Chain # 9-182
  • Tming Chain Damper # 9-5138
  • Timming Chain Tensioner # 9-5137
  • Timing Cam Sprocket # S-532
  • Timing Crank Sprocket # S-529
These are separate part numbers from the LL8 '87-'89 121CID(2.0L), LQ5 '83-'86 121CID(2.0L), LR9 '83-'84 121CID(2.0L), LM3 '90-'91 134CID(2.2L) and all '92-'02 134CID(2.2L) OHV Chevrolet catagories. None of the part numbers interchange between the '82 and other catagories.
Adavance Auto Parts / Parts America lists these components part numbers (w/o the dash) in their online catalog and state 2 day delivery to my local store. I thinks me iz going to check it out!
AutoZone lists the Cloyes 3 piece set (acooring to their online catalog it's correct part number) and they list the dampner (Cloyes with same part number as Mahle/AE Clevite), but no tensioner.
Sunday, April 13, 2008 10:23 PM
very good information and another great read!
Tuesday, April 15, 2008 8:54 PM
MadJack wrote:Josh, reading this thread, got me to thinking and I looked something up. I don't know if you remember, a while back Mahle bought out AE Clevite. I did some checking and guess what I found! All the timing components for the '82 1.8L L46 motor!
POST OF THE MILLENIUM!!! I hope they're true double-rollers...Shannen was running into some single-roller setups IIRC.
If they're double, I'm going to buy a few sets and have all the cam gears bored out at once.
I still want someone to try the newer tensioner though...
Tuesday, April 15, 2008 11:57 PM
whats so good about the double roller conversion? i think i remember reading about it on another post but i can't find it.
Wednesday, April 16, 2008 8:56 PM
SO_hardcore wrote:whats so good about the double roller conversion? i think i remember reading about it on another post but i can't find it.
It's stronger (and louder )
Thursday, April 17, 2008 7:08 AM
Less prone to stretch and wear. Especially with stiffer valve springs. Its why you'll see on some Grand Prix GTP oriented sites that they don't recommend using the stock chain with valve springs over XXX-lbs of pressure.
Eco
Turbo
Megasquirt
Saturday, May 17, 2008 8:32 PM
Yes, I'm bringing this one back from the depths of last month.
Last weekend, I pick up a '97 2.2L motor, wiring harness and PCM. When I got it, later that week, I went ahead and ordered a set of the L76/L92 valve springs from Scoggin Dickey Parts. They came in today.
These are the spec from the GMPP catalog:
12589774
• Max lift .530"
I took a few measurements my self. Sorry, I don't have a spring tester to check the rates, but I can give you these:
  • Free Height: 0.141"
  • Base Outside Diameter: 1.270"
  • Base Inside Diameter: 1.270"
  • Top Outside Diameter: 1.080"
  • Top Inside Diameter: 0.673"
  • Wire Diameter: 0.203" X 0.166" (ovate)
  • Active Coils (Bottom 2 are closer windings)
  • Ends: Closed and Ground ( Valve springs normally are)
These are just a few quick measurements, so you'll see some of the math will be a few thousandths off, but it should give you a good idea of the dimensions.
These seem to be the right dimensions to fit the 2.2L head and retainers, with the spring pockets machined 0.090". When I get some time, I'll disassemble the head and check the fitment of the retainers and the diameter of the spring pocket. I have a feeling they should fit.
Saturday, May 17, 2008 8:36 PM
holy information!? i'll have to read this one with coffee tomorrow....
Sunday, May 18, 2008 1:32 AM
So Jack, about those K-motions and retainers you were looking to offload........
Eco
Turbo
Megasquirt
Sunday, June 01, 2008 1:01 PM
I finally got around to pulling a couple of valve springs from the '97 2.2L head I recently acquired. I figured I'd throw out a pic of the valve springs:
The spring on the left is the L76/L92 valve spring and on the right is a '97 & older LN2 valve spring.
The retainers on the top of both springs are the LN2's. They fit both springs the same, so if you questioned the fitment of the retainers, no need to worry. All you need to do is machine the seat and guide down 0.090" and you'll be ready to install these springs.
Sunday, June 01, 2008 7:53 PM
so what about the 2200 guys? could we use the 2.2 valves machine the head and guides and use these? and what about using these with roller rockers?
DRIVE HARD OR DONT DRIVE AT ALL!!!
Sunday, June 01, 2008 11:46 PM
CAVI.DEMON wrote:so what about the 2200 guys? could we use the 2.2 valves machine the head and guides and use these? and what about using these with roller rockers?
x2
Monday, June 02, 2008 2:52 AM
So far the only thing anyone has been able to come up with for the 2200 is to use the '97 & older 2.2L valves (or get some custom made +0.100" @ approx. $30+ ea.) to get the added installed height for the springs. Problem is you need to space the valve cover up (Phil's planned prototype), get longer pushrods and we're not sure if the ARP 8mm base / 3/8" top studs are long enough to stably hold the rocker arms.
Monday, June 02, 2008 7:04 AM
Hmmmm, listening.....
Monday, June 02, 2008 6:03 PM
On the chain: Even if you don't have higher rate springs, or just simply have this engine is a S-truck (Like I do), the factory Timken-link "quiet" chain always seems to fail around 100,000mi & is a big fustraition. Especially if to the tensioner frags & pieces go into the pan. If you fail to get those out, get ready to say hello to a new engine (I did. Stupid wrench before me!). The LN2 is a workhorse basically, and like any other GM workhorse it seeing a failure-free duty range of 300,000mi doesn't seem unlikely. The only thing holding it back from it the quiet chain. I bet if it were replaced with the double-roller it could easily make it.
Go beyond the "bolt-on".
Saturday, November 22, 2008 12:23 PM
I found these, they'll fit the '97 & older heads without any machining, using the stock locks and retainers.
Comp Cams Part #26981 (Beehive™) Valve Springs
• Designed for hydraulic or solid flat tappet cams well as hydraulic rollers
• .525 maximum lift
• 1.240” O.D. , .825" I.D. Bottom
• 1.065" O.D. , .650" I.D. Top
• 110 lbs @ 1.70" seat pressure
• 292 lbs @ 1.175" open pressure
• 1.115 Coil Bind Height• 347 lbs/inch Spring Rate
Edit: You will lose about 3.5 lbs of seat pressure, because of the stock installed hight of 1.71" on the OHV. Your motor will never notice the difference!
The Part number for the set of eight is 26981-8. they are available from Summit Racing.
They can also be used with the '98+ 2200s , if you use valves with +0.100" valve stems and +0.100" pushrods. The VC will need to be spaced up also. Make a spacer out of 1/8" thick material (steel or aluminum) the same shape as the valve cover rail on the head.. Use RTV silicone to seal it to the valve cover rail on the head. The valve cover screws will need to be appropriately longer to fit the spacer.
Edited 1 time(s). Last edited Saturday, November 22, 2008 12:30 PM
Sunday, November 23, 2008 6:29 PM
Hmmm, Listening.
I think this info can be used on LD9's as well
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
Wednesday, December 10, 2008 8:00 AM
MadJack wrote:I found these, they'll fit the '97 & older heads without any machining, using the stock locks and retainers.
• .525 maximum lift
Nice find! Why has there not been more discussion of these?
11 speaker JL Audio stereo setup for sale:
http://www.j-body.org/classifieds/audio/52021/
Wednesday, December 10, 2008 5:54 PM
Yeah, I wish I had seen these before I bought the L76/L92 springs. The 26981s are more expensive, but less expensive than getting the springs and machining the spring pockets.
I keep finding the better parts after I purchase the previous ones!
Wednesday, December 10, 2008 8:39 PM
Tell me about it. I have 4 sets of LSX springs in the garage...
