do you have to prime the oil pump? - Performance Forum
Sunday, December 09, 2007 6:38 PM
like the tittle says when you do the swap to the 2.3 pump do you have to prime it? my pump is not picking up any oil at all. and if you do how do you do that.
Re: do you have to prime the oil pump?
Sunday, December 09, 2007 6:44 PM
Dump oil in the pump, and also in the pickup, bolt it together. Crank the engine over with the fuel relay out for a bit. That's what I did and it worked great.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Sunday, December 09, 2007 6:57 PM
when we a 2.4 all built we do it on the bench (turn the engine over) and make sure that the pump is working properly and such... if it is oil will come out of the end of the intake cam and yull know its good.
also a good way to check compression and cranking pressures etc.. really works awesome.
Sunday, December 09, 2007 7:20 PM
but if the engine is in already and i dont have a psi gauge how else can i check or do i have to buy an oil pressure gauge?
Sunday, December 09, 2007 9:17 PM
Just pull the fuel pump relay and your spark plugs Then go ahead and crank it. This way it does not have fuel washing the cylinder and it does not have the resitance and strain of compresion to slow the cranking process.
Monday, December 10, 2007 12:47 AM
Wade Jarvis wrote:Just pull the fuel pump relay and your spark plugs Then go ahead and crank it. This way it does not have fuel washing the cylinder and it does not have the resitance and strain of compresion to slow the cranking process.
Do this but then also take the plug on the drivers side of the intake cam tower out. turn it over tell oil starts coming out.
Monday, December 10, 2007 12:21 PM
frikken sunfire wrote:but if the engine is in already and i dont have a psi gauge how else can i check or do i have to buy an oil pressure gauge?
The car has one built in, it just doesn't read specific numbers. The little oil light is oil pressure. If it is lit then you're not meeting the stock requirement. The stock engine shouldn't need the oil filter primed, this is most commonly for turbo/supercharged engines. You may have a bad pump.
_________________________
Monday, December 10, 2007 12:27 PM
Scratch that, didn't read the post right, yes, you have to prime the pump. Fluid dynamics, the air isn't dense enough to pull the oil up.
Monday, December 10, 2007 1:53 PM
you do not need to prime the pump if you just take the plug out the side of the cam tower and turn it over for a few secs then you know oil if flowing to the top of the engine meaning you good to go.
Tuesday, December 11, 2007 10:37 AM
i will try this today cause i want my car to run good, would that quite down the knocking on the top of the engine?
