this is on a 2.4L ....ok so i have all of my AC ripped out except the compressor.... i do not want to put the delete pulley on there because i have heard you can just run a shorter belt
2 questions
is this safe?
what is the belt #?
I would like to the know the same thing and also about the 2.2 ohv
What belt for a 3rd Gen J-Body running a 2.4 twin cam no A/c, no delete pulley?
also
What belt for a 3rd Gen J-Body running a 2.2 OHV, no A/c, no delete pulley?
anyone able to help us? or are we going to have to do it trial and error style by getting some belts and seeting what works by estimating the length?
Do a search Suncavi had posted this for the 2.4 once.
and the 2.2 ohv's they came with out a/c all you need is the non a/c belt
I know this thread is old but I couldn't find anything about what belt to use for the 2.4
I want to bypass my a/c cause it's making that awful noise and I'd really like to know what belt I need to get to do it
thanks...
the belt part # that i have saved is: 345K5
That is the part # suncavi gave a while back for it, and i still have yet to do this to my car, so can someone verify that belt #, i would hate for it to be the wrong one.
Goal is to make my N/A Auto faster then a manual without doing engine internals
Just go in and ask for a 33inch belt...
I believe thats what size it is....and make sure you go around the idler pulley.
Ok I'm bringing this back,I have tried numerous belts after taking out the a/c in my 2.4,I was running a 350k5 with the tensioner pulley,started squealing here and there,I removed the tensioner and ran the 345k5,had to loosen the top two alt. bolts to get the belt on and tightened everything back down,started the car up and it started squealing and smoking.Shut the car off and loosened the two alt. bolts a little,it gave the belt a little slack and car ran fine at idle but squealed loudly when I gave it gas.So do you think the bearings in the alt. are going or just the belt being too tight??Anyone have a quick link to buy the a/c delete pulley?
bump
im about to do this to ... did you ever get it to quit squeal if so what was the problem . and can you by a ac bypass pully for the 2.4
I ran a 350K5 for a while, and ended up just using my delete pulley since I could never get the belt to no squeal after a few months.
where can i get a delete pully at for a 97 2.4 ?the dealer or some where off the internet
I got mine from the dealer....but there are a few on ebay every once and a while.
