Is there any free mods, meaning mods I can do myself at home that I can do to me engine? I already have headers and 2.25 back and Intake and a crank pulley on the way. I just didn't know if there were any tricks I could do time consuming or not. I ran a 15.6 1/4 last night at the track and I am trying to improve, thanks
<img src="http://www.j-body.org/registry/twiztid04cavy/jbodysig.JPG">
if you bought 2 headers, your gonna have to send one back, there is only 1 on the car.
You can do weight reduction, Remove the air bong if you havent yet. Daily maintance, etc.
true.
Cannon fodder is my daddy.
change fluids
put the stock wheels up front for the track
also maybe you should update your profile
strip your interior. remove spare tire and jack. remove front side passenger seat, and rear seat and jsut about anything else that will come out
![](http://i134.photobucket.com/albums/q109/99redz24/camarosig.jpg)
I could remove the spare and the jack from the car. Anyway I have GM service for another year and half. They will tow me if there is anything
My Car Specs
Club J-Body Montreal Forums
Yea sorry I meant header, and i just havn't had time lately to update my profile but if it makes you happy it's updated now. Any other mods besides weight like any restrictions?
<img src="http://www.j-body.org/registry/twiztid04cavy/car051.JPG">
it depends on yout skill and the tools you have available
If you're good with a carbide cutter, you could port your intake manifold. Check my other thread for pics.
you could pull off the cylinder head and port that, but thats not really a fast or fun mod. it also costs money to replace the gaskets you would use putting it back together.
<a href="http://www.j-body.org/members/speedvisioncavalier"><img src="http://www.j-body.org/registry/speedvisioncavalier/new%20sig.jpg"> </a><img src="http://www.precizion.org/animatedz.gif">
"What are we going to do tonight?"
"The same thing we do every night, try to make the SVC go faster!"
Toss an intake on it like my pic below. Wouldn't reccomend the weapon R though, I hate everything about it but the sound.
intake... make your own intake
maybe do that cheap hack motor mount trick. There is some sort of chemical you can get and use on you rmotor mounts to make them supper stiff.
You mean fill them with epoxy ? Just go buy the mounts and do it right.
if you have access to a torch and a spring compressor you can cut your springs. can only do one coil off of the top though. before anyone says, "you can't do that....your shock will collapse and you'll fly straight off of a clif and crash and burn, and die and stuff." yeah, that's not going to happen. if our cars came with progressive rate springs, well that's a different story.
CAR GODS MADE THE 1.6 SOHC TO MAKE US 2.2 OHV GUYS FEEL BETTER.
^^ that's dangerous, stop suggesting that, nobody should be cutting their springs
secondly, that's not an engine performance mod
yeah, i was thinking free. it's not dangerous, but you have to use a torch so that the end of the coil bends down slightly so it seats correctly. and only cut off of the top.
Do what 04Firetec suggested. It works beautifully.
No don't do that, Heat treating springs to bend them is terrible the metal becomes brittal and can break at any time, you need to remember that you will be more bouncy and will add more stress to your springs, they will crack or break... just save up 200 bucks and do it right.
^ it's not going to change spring rate on a linear spring.
hey theL61, did u make your own intake? I am trying to figure out how to do that I know i can make the piping I am just having problems with the throttle body making a boot or something to mount to it?
Off topic but do you ever go to muncie for Fun Friday? I once met a girl from Anderson that worked at Hooters while i was cruising in new castle on night
If your interested in custom aluminum tilt wheel levers hit me up!
Fatalic CAVI wrote:No don't do that, Heat treating springs to bend them is terrible the metal becomes brittal and can break at any time, you need to remember that you will be more bouncy and will add more stress to your springs, they will crack or break... just save up 200 bucks and do it right.
chapter10 wrote:^ it's not going to change spring rate on a linear spring.
Chapter 10 you are an idiot, everything Fatalic said was right, think about it, lets say they design the coil spring to have 7 coils in order to suport the wieght of the car, now lets complete cut one off.... so the metal thats left gets more stress then its designed to take (its not about the spring rate you dip@!#$ its about weight distrobution, the more even the load is spread out the less strees on the parts holding the load) so not only are you increasing the load but you say to heat it on top of that which just like fatalic said will make it brittal.... plus you blow you stock shocks..... so a brital spring that bounces more then its surpossed to while surporting more weigth then its surpossed to.... real @!#$in safe. STFU and quit trying to get people to rig there cars
Do me a favor go take a gun, load it, point it at your head, then heat it up with a torch. You don't heat springs, unless your going to the Demolition derby, or your on Junkyard wars.
This is whatI say to all the DUMB @!#$ that think its ok to cut springs..
Obviously money is tight if you are even thinking about cutting the springs... Just goto ebay and get the cheap ass coilovers for like 30 bucks slam the car 4" have a @!#$ty ride and then have the coilovers break in 6 months ... another cheap half ass way to solve your problem
BTW ken love that sig
Team Altered Car Club
