very very high idle!!! - Maintenance and Repair Forum
Monday, March 26, 2007 4:29 PM
i just replaced the starter in my car its a2.4liter , i hooked everything back up the way it was supposed to be, now when i start the car, it revs at 3500-4000 rpms, and doesnt go down, anyone know what the problem could be?/???
Re: very very high idle!!!
Monday, March 26, 2007 7:30 PM
Did you check the IAC and MAP sensor vacumm line, when any of those parts are not pluged the idle acts funny.
Monday, March 26, 2007 7:38 PM
Check all vacuum hoses ...
Tuesday, March 27, 2007 5:07 AM
JerseyKid ( EPIDEMIK ) wrote:Check all vacuum hoses ...
Tuesday, March 27, 2007 12:09 PM
i have a hole in one of the vacuum lines going into the intake manifold, would that do it?
Tuesday, March 27, 2007 12:27 PM
just to add to my last post
i had to bypass the ignition switch, because either a relay is bad or something else is bad
i tested the positve going to the starter, but it had no power going throuhg it, im guessing it is a bad relay
so right now i have the starter on a switch, just put the key in the ignition, turn it on, and hit the swtich to start the car, but when it starts its at 4000 rpms at idle
Tuesday, March 27, 2007 12:59 PM
ok what sensor is that, and thats the vacuum line, which goes into the intake manifold, and the sensor
Tuesday, March 27, 2007 1:06 PM
i taped the vacuum line just to see if that was it, but it wasnt.... yeah i know im cheap, but im also completely broke, thats why im doing it and not having someone else do it
Tuesday, March 27, 2007 1:58 PM
If you pull that apart theres a color seal inside... Red Blue Or Green. I forget what each color it is, but i can bring home my notes tommarow and let you know what it is.
According to ALLDATA, it looks like your MAP Sensor
so i dont know if that helps you at all or not
Tuesday, March 27, 2007 2:15 PM
is there anyway to check to see if its faulty?
Wednesday, March 28, 2007 12:02 PM
bump
Wednesday, March 28, 2007 3:42 PM
anyone? anyone at all?
Friday, March 30, 2007 10:46 PM
bump
Monday, April 02, 2007 4:34 PM
That is your pressure sensor (MAP sensor) for sure, I had a bouncing high idle once and it was the short vaccum line that attaches the MAP sensor to the throtle body that came loose, twice it happened till I secured it with a tie wrap, never hapen again I think I had to reset the comp. Donīt know how to test it thou, sorry, hope someone posts how. The MAP has a label:
" Pressure sensor
5V OUT GND and a part nbr."
Monday, April 02, 2007 4:45 PM
Manifold absolute pressure sensor is what chilton calls it.
Monday, April 02, 2007 5:06 PM
Emailed you a procedure. Good luck.
Monday, April 02, 2007 5:45 PM
thanks much man, but i already tested it, i think my troubles lie in the ecu tho because now if and when it starts its misfiring
Thursday, May 10, 2007 2:46 PM
i have the same problem i checked it today and my vacume hose from the map to the Tb was broken so i replaced that and checked everything and still misfires and idles high have you fixed yours yet and if you did what was it?
Thursday, May 10, 2007 2:59 PM
Did you replace that vacuum line going to the map sensor yet?
Thursday, May 10, 2007 3:03 PM
yea already replaced that and cleaned everything
Thursday, May 17, 2007 2:26 PM
Dont mean to bring back a old post. But where is this line located? That little hose? I cant seem to find mine to check it out.
Saturday, May 26, 2007 11:26 PM
a friend of mine was telling me about a cav they had for sale on their lot, needed a lot of work done it, one of the problems was that it idles high. as to why, apparently some sensor needs to be replaced because it ithinks the A/C is on so it idles high to power the alternator more. maybe look into that, or i might be talking nonsense i dunno
Saturday, June 30, 2007 9:17 PM
did you take your cables off your throttle body at all? i had one of those linkages pop off and it idled high and it wouldnt go down.. you gotta push on those mofos really hard to get em to set..
"Z24 Dustbunny"
Thursday, July 05, 2007 6:09 PM
reset the computer, unplug the battery for atleast 10 minutes
i think the ECU's run on windows 95
-thomas
Friday, July 06, 2007 11:17 PM
Thomas Sweeney wrote:reset the computer, unplug the battery for atleast 10 minutes
-thomas
Nah, DOS is what I heard. Still Microshaft though.
